Removing Trim On B Pillar
TruBlu
Because of an annoying rattle or wobble sound coming from the inside of the trim on the drivers B pillar, I need to remove the trim around where the seat belt exits. Has anyone done this and if so how easy is it to remove? There are some clips that attach to the trim that go under the seal around the frame but it still seems hard to remove - would I just pull the trim off the pillar with the seat belt running through it?
Any ideas? - I wouldn't want to crack the plastic
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
