Fault Code P1220
robinson5599
Does anyone have a clue as to what fault code p1220 is, it says "timer control circuit malfunction"?
What and where should we be looking
It turned out that the cambelt which had been replaced at 63000 by previous owner, was one tooth out on the injection pump.
So if your car returns from garage after cam belt change with poor performance, iffy starting and generally not right, have them recheck the timing, or better still, send to a garage who know what they are doing.
Glad it's now sorted and thanks for the update on the problem !
Les
  • 7 years later...
