Headlamps
halfpastsix
Does anyone know if the 1997-2000 model Rav4.1 headlamps fit on the earlier models?
far as I know.
it is possible but you do have to find a way of fitting the sidelight as the sidelight is in the combind with the indicator. you can get what are called angel eye headlamps for your car have a look on eBay
Cheers. So if I buy a set they will fit and work, but won't have sidelights. Not too much of a problem to sort. Do the newer lamps work any better does anyone know? I've found the lights on mine a bit feeble.
mrbilly, I've seen those, but they have projector lenses in them. I don't like these. The best lamps I ever had were on a Ford Ka. Try one at night on dipped beam and you'll see what I mean. I swapped them for the angel projectors and they were rubbish, so they got taken off and sold back on eBay.
My Puma also has projectors and they are equally as useless.
