Engine Stalls
toyota_ch1ck
:help: I have a 1991 Celica ST 1.6. she drives fine but sometimes when I am stoped like at a light, Idle bounces and car sputters then stalls..
any Ideas?
I'm having the same problem, but mine seems a bit more severe. It's worse when the engine is cold and when i lift off the accelerator, the revs drop and don't catch at the idle, just keep falling. Sometimes it catches it at 300 or so rpm and after a few seconds picks back up, sometimes it just stalls. It also doesn't idle very steady, lots of movement on the needle. When it stalls out, and i restart i have to pump gas to get it to start - i'm thinking its the fuel filter - so i'll look at this first.
Basically it could be one of a thousand things - you need to look at whether it happens all the time or just when air con or lights are on - this means it is electrical. It could be:
Leaking vacuum hose
Faulty plugs, leads, dissy cap or rotor
Faulty fuel pump, filter or injector
Timing out
These are the main problems, but it could be EGR valve, blocked air filter, or loads of other stuff. If you can't find it, look at taking the car to toyota dealership for a diagnostic machine run.
Good luck
Shortty
