How To Reset Your Auto Electric Window Function.
GIDDLEPIN
How to reset your Auto electric window function.
If, like me, you let the wife use your beloved Auris to pop down to the post box when the weather's freezing and, if like my wife yours decides to wind the window down to clear the ice off (?????)... and, if like mine, your window is frozen solid and it stops the auto function working and causes the auto light on the switch to flash, here's the procedure to reprogramme the auto wind unit.
Simply turn the ignition on, wind the window all the way to the bottom and hold the switch down for at least ten seconds. Then wind it all the way back up again and hold the switch for another ten seconds and voila, the system's reset!
Good find and advice, as I thought I was the only one with a wife who did this type of thing.
Perhaps one of the things that could be placed in a sticky reference type folder which is pinned at the top of the Auris section, as general advice for the future?
Whoops, sorry, just seen you have already done it.
