Creaky Clutch
jambbie
My clutch pedal on my '04 Avensis has become "creaky". The noise seems to be coming from the footwell. The clutch itself seems fine, as when u depress the pedal a little bit and pump the clutch there's no noise and no resistence. however when you release the pedal into the fully up position it creaks. I have wd40'd and greased up anything metal in the footwell.I got a week or so out of that but now the creaky noise is back ... any ideas please
Hi mate, this is quite a common problem and normally due to pedal pivot bushes, I have attached a drawing of the pedal assembly, on the drawing you will see arrowed where the grease is required.
Pete.
post-74463-0-91718600-1299270318_thumb.j
Pete.
Thanks a lot for your very helpful reply pete.. much appreciated...
As i'm a joe soap with limited mechanical know how, can i ask you if i need to get this disassembled, greased up and reassembled, as there's some of the mechanism a bit out of reach and i think this is where my noise is coming from.
Ta Again mate .. fair play to ya
Pete.
Hi again, yes it does need to be stripped down to do a proper job and in saying that new bushes should be fitted. It will not be a nice job to do as there is little room to work in under there, probably easier with the drivers seat removed.
Regards .... Pete.
Pete.
Regards .... Pete.
Cheers again Pete.. much obliged
