None Genuine Parts- What Do You Use.
avensisd4d786
Hi guys sometimes dealers parts are overpriced even with trade prices, well for me anyway.
what aftermarket/oem brands do you use for your avensis.
and if you get them online a website would be appreciated.
or are you one of them who swear by Mr T parts?
Blueprint or ADL
I will fit anything that I can get that is cheaper than Mr T
The only part I use which must be genuine is the engine oil filter. Everything else is aftermarket. Always Mintex for brakes and discs. Everything else is usually motoquip.
Blueprint or ADL
Yeah I've heard blueprint are good. I thought blue print & ADL are the same, sorry for ignorance.
Do you buy them direct from blueprint or from your local dealer?
Yeah one of local dealers sell mintex and motaquip, Ive recently got mintex pads in :| but they squeal sometimes when braking slow, not as much as they used when i first got them put in, have you found this
I've not experienced that. That can sometimes occur if only the pads are replaced and the old discs have wear ridges.
Probably, do you buys yours online or from you local parts dealer.
I've only ever used genuine Toyota parts. Apart from the brake discs (MTEC) and pads (Mintex) and the Mobil 1 ESP oil she loves...
