In order to get a warenty replacemnet for my sub I need the receipt, the first time I got the sub I didnt need the receipt, what can I do, Ive looked everywhere for it.
I know that they put some comments about my car in their diary but that wont count, can I go to alpine?
and another thing they guy who I got the sub of is a bit of a *****
tbh mate... looks like you're screwed!
credit card receipt?
I payed by cash
More fool you then ..
A receipt is desirable but not a necessity.
"I have purchased some faulty goods, but unfortunately I have lost the receipt. The trader says that, because I do not have a receipt, I do not have any rights. Is he right?"
No! You do not have to produce a receipt in order to pursue a claim for faulty goods. However, under the law, you are required to prove that you purchased the product. Therefore, if you paid by cash, a receipt may be the only proof that you have.
Hope this helps... :thumbsup:
Or write to them, copy and paste and replace the bits with your details
REJECTING FAULTY GOODS
Dear Sir/Madam
REF: XYZ CD PLAYER/Sub/etc
On 1st March 2003, I bought a XYZ CD player from your Anytown branch. Now, nine days after purchase, the player is completely defective, and none of the functions are operating.
On complaining to the shop manager, he told me that I had to return goods within seven days, and that it was now the manufacturer's problem. The Sale of Goods Act 1979 (as amended) requires you to supply goods of satisfactory quality. I must be given a reasonable length of time to examine the goods before accepting them. I think that nine days is still within a reasonable time, and that this fault means that the CD player is not satisfactory. Further, as I bought the goods from you, my contract is with you, not with the manufacturer.
Therefore, I am notifying you that I am rejecting the goods based on your breach of contract, and request a full refund of my money within 14 days of the date of this letter.
Yours faithfully, etc.
Basically if you are in the right then u should be able to talk anyone around.....I have done it so many times. It is sometimes referred to as a blag........
If you put ya mind to it then almost anything can be moved in your advantage court. :thumbsup:
If it's an electrical item then ask them to cross reference the seriel numbers and that will prove its age and date of sale. Ipso facto if within warrenty then you should then have the details on computer there as a bargaining tool......
Good Luck with it. and don't take no for an answer..... :thumbsup:
computer, the receipt was hand written, they might have a carbon copy, will try out the S/N
what sort of place uses handwritten reciepts nowadays? :unsure:
The sort of place you should turn around and walk out of...
people selling things out the back of a lorry :P
no its a proper audio shop,. gonna look for it again , or try alpine
Subject: Re:
To: "Http://VMail.TK"
X-Mailer: Lotus Notes Release 5.0.9  November 16, 2001
X-MIMETrack: Serialize by Router on AOGMLN001/SRV/AOGS/SPEED(Release 5.0.12  |February
13, 2003)
X-Antivirus: avast! (VPS 0427-0, 29/06/2004), Inbound message
X-Antivirus-Status: Clean
.... Also the connection method to the amplifier, even though they are
in series are you sure that the coils are wired in phase ?
At 8 Ohms the amplifier would be 100W @ 14.4V. The amplifier is designed to
run with a 2 Ohm load and will then produce 350W @ 14.4V.
Regards
Barryjohn Vincent - Assistant Technical Manager
AOUK - Technical Department
Tel : +44 (0)870 3333 xxx
Fax: +44 (0)870 3333 xxx
what does he mean by "are you sure that the coils are wired in phase?"
looked at the sub for the first time, I was told that it was wired as series, but it wasnt
from that drawing it is wired wrong!
vmail thats wired wrong from your pic!!!!
unusual for someone who's done over 250 installs to get something like that wrong! :!Removed!:
thought you were exprienced in things like that....
obviously not! !
yeah, i have to say vmail, thats a very basic error there!
whoever installed that didnt have a clue what they were doing.... I'd have serious words with whoever did it mate :ffs:
I didnt fit the sub, Ive only done single cones, so how should it be wired then? they kept the instructions and box
look on the instructions!
it is extremely clear on how to do it
I dont have them, they(the company that fitted it) kept every thing
I shouldnt of fallen for the free fitting
take it back and say its wrong
how should it be then
from the amp the +ve should go to one coil and the -ve to the other coil
the two coils are the connected together again over the unused +ve and -ve terminals
that would make it 8Ohms I think, but they have wired it as 2Ohms
