This is my first post. Just picked up my wife's ex-demo Aygo+ with air-con yesterday, and I need some advice regarding fitting the Nokia hands-free that used to be in her other car.
I've worked out how to remove the head unit to access the wiring, but does anyone know if it's possible to have the hands-free mute the stereo or if it's possible to hook the audio output into the head unit rather than have to try to find somewhere to fit the Nokia speaker?
Thanks,
Graeme
The radio in the aygo is fitted wit ISO-connectors. There's
2 large ones with 8 pins each; one for power, one for Speakers.
They can't be swapped because of the locking-tab being positioned differently:
A-Block Power:
A1 = phone mute/tach pulse
A2 = remote/ground
A3 = remote
A4 = 12V permanent IN
A5 = 12V switched OUT (i.e. for antenna or amp)
A6 = 12V IN when lights on (for screen-light or dimmer)
A7 = 12V switched IN, powered whit key in ACC or IGN
A8 = zwart (bruin), massa
B-Block Speakers:
B1 = + right rear
B2 = - right rear
B3 = + right front
B4 = - right front
B5 = + left front
B6 = - left front
B7 = + left rear
B8 = - left rear
C-Block Auxilary
C1 = line-out left rear +
C2 = line-out common ground
C3 = line-out right rear +
C4 = line-out left front +
C5 = antenna/remote +12V OUT
C6 = line out right front +
C7 = n/a
C8 = n/a
C9 = n/a
C10 = n/a
C11 = phone in +
C12 = phone in ground
C13 = cd id (data channel)
C14 = n/a
C15 = ground
C16 = +12V OUT permanent (feed for Changer)
C17 = +12V switched
C18 = CD-changer line-in ground
C19 = CD-changer line-in left
C20 = CD-changer line-in right
The radio DOES have this C-Block, and I think the pins
you need (C11 and C12) are functional, as Toyota also
fits Hanndsfree kits with sound over the stereo...
Can't test it for you though, as I ditched my Toyota radio
(actually it's a Panasonic) the first day after taking delivery
of my Aygo in favor of a Kenwood KDC-PWS9524 I allready had...
The above pinnings were translated from a
Dutch site, so I might have made some mistakes.
Also note that even though ISO is supposed to be an world
wide standard, some manufactors choos to differ from them
(like VW/Audi/Skoda/Seat having the A4 and A5 signals swapped),
so ALLWAYS test/measure your plugs before connection anything up.
Mess it up? Not my fault!
Thanks guys.
I've ordered some leads and a no-holes bracket. I'll report back when I get it installed.
Thanks,
Graeme
  • 6 years later...
2 large ones with 8 pins each; one for power, one for speakers.
A-Block Power:
A2 = remote/ground
A3 = remote
B-Block Speakers:
B1 = + right rear
B2 = - right rear
B3 = + right front
B4 = - right front
B5 = + left front
B6 = - left front
B7 = + left rear
B8 = - left rear
C-Block Auxilary
C7 = n/a
C8 = n/a
C9 = n/a
C10 = n/a
C11 = phone in +
C14 = n/a
C15 = ground
C17 = +12V switched
I was looking at the user manual in the peugeot 107 (from the net) and noticed that they have labelled A7 as permanent positive and A4 as accessory positive (thro' ignition key) and that is totally opposite to the diagram above. Here is a copy paste from that manual. This explains why my Mutant radio has been playing up with clock and equalizer settings after installation. Mutant pins are exactly like the ones that Jan Van posted above but the Aygo/Peugeot pins are in reality different to that picture above with regard to the A7 and A4 pins. Jan Van where did you get that picture from please?
PRACTICAL INFORMATION 9
79
FITTING AUDIO EQUIPMENT
Your vehicle is equipped with certain
factory-fitted audio equipment:
- roof aerial,
- coaxial aerial cable,
- basic interference suppression,
- supply to front Speakers,
- two 8-way connectors.
FITTING Speakers
The factory-fitted equipment allows
the fitting of 100 mm diameter Speakers
on the fascia.
As accessories, you can fit 165 mm
diameter speakers on the rear shelf.
Making the connections
A1: -
A2: -
A3: -
A4: (+) Accessories
A5: -
A6: (+ve) Side light
A7: (+ve) Permanent
A8: Earth
B1: (+) Rear right speaker
B2: (-) Rear right speaker
B3: (+) Front right speaker
B4: (-) Front right speaker
B5: (+) Front left speaker
B6: (-) Front left speaker
B7: (+) Rear left speaker
B8: (-) Rear left speaker
Consult a PEUGEOT dealer
before installing audio equipment
or speakers in your
vehicle.
