Cruise Control Installation Instructions
Speed_Chaser
Here is how to install Cruise Control to your Auris...
Found this instruction on Toyota Owner's Club Russia
-forum, special thanks to Andron, who took the pictures
and wrote the russian text!
I made some improvements and posted it here, enjoy...
You're gonna need two parts:
Cable
and switch
(You can see the part numbers on the pictures)
Next you have to connect the wire to the switch
After that, remove the cover caps from both sides of the wheel
After removing you will see the following:
(there is a possibility that the caps don't exist, if so, you'll see one screw on both sides of the wheel,
and should just continue to the next step)
Remove the screws (TORX 30).
Pull the airbag covers' upper side towards yourself. DO NOT disconnect the airbag's wire!
Put the switch to it's place from the inside of the right hole (or make the hole in case
you didn't do the "remove the covers from both sides of the wheel" -step because of
not having any covers.
After that just tighten the switch with two M5x10mm, not M6
screws
  • Like 4
Under the airbag cover you'll see the connection places, the one on the right is free
Connect the wire to it
Insert the wire as it is shown on the picture below
After it's done just put everything back as it was...
Turn on the ignition and push the "ON/OFF" button
Everything is ready and working just fine!
Now all you need is a test drive... But please read how to use the Cruise Control
from your Toyota owner's guide!
You cannot install Cruise Control if your car has 4ZZ-FE -engine!!
Great contribution, and I am sure there will be quite a few people out there for whom this will be very useful.
So if you can just buy the cruise control from Toyota and a cable and then conenct them up??
That's correct!
The switch and cable come to £72.44 delivered to any UK address, overseas will be higher
Are you saying that the Cruise function is already on the car and you just need these two parts to enable it? If that is the case it seems a remarkably cheap cruise control. I am sceptical :rolleyes:
Kingo :thumbsup:
Will this work for 1.4 D-4D Auris with Manual Transmission?
I don't know, but you will find it out by checking that the engine type isn't
4ZZ-FE, with others it should work, even if you have manual gearbox.
Other things that you should check is to look at the left from the RPM
display (on the upper side of the handbrake -light)
in a sunshine or by pointing there with lamp, if you'll see there
the text "cruise" (which lights up when the controller is installed and
is shown on the last photo of my instructions), then
you should have the option available.
But this is not 100% sure information, so please check the availibility
of cruise control to your model also from your Toyota dealer or from the
user's manual. Good luck to you!
Kingo :thumbsup:
It is a fact that every Auris has Cruise pre-installed because they have the green "cruise" -light on the dashboard (or whatever, you know, at the left side on the speed/rpm display...) You can see it by looking in good lightning. So I think if there's a pre-installed Cruise in the car, the whole operation isn't very difficult if you want to install the cruise afterwards. It's just that the dealers make a lot of money by doing the installation themselves, because no-one really knows what do they do and how easy or difficult the installation really is!
Regards, Alex
Regards, Alex
It is quite normal for some car manufacturers to fit the things (almost) but deactivate them and enable when you pay extra. That lower the manufacturing cost I believe. That way it took only few minutes to have heated mirrors in some older VAGs (all the cabling was there) or heated seats on some Volvo models. Computer that regulates the throttle has probably CC options programmed in so it is just a matter to hook up into it (I am guessing).
Thank you for the detailed reply brother!
I checked the manual, my engine is 1ND-TV.
Then I went to garage and looked at the display with a flashlight, I definitely could read the CRUISE. :)
Then I checked my steering column for the caps you said. I have one right under the star screw, near the ignition. :D
So this means I can install cruise control, yes?
Ok I have a base model 1.8 litre Auris (Corolla in Australia) and I called the dealer to ask about the cruise control and he quoted me $5000 :o
I said can't I just buy the lever and install it after, he said that apparently Id need to change computer modules in the car and I am better off buying after market cruise control.
Is he for real?
As well as the steering wheel control the cruise control needs to know when any of the pedals are being pressed. If you press the clutch or brake when the cruise control is on it should cancel the cruise. If you press the accelerator with cruise control on it should let you accelerate and then resume cruise after you release the pedal. Even if the sensors are already in place for all of the pedals is the software that sends this information to the cruise control system enabled?
It sounds like you can go for it... Great to hear that your car has these options, so you have the chance to install Cruise!
I've just read on the russian forum, that when you press the clutch, the Cruise is disabled... But it is not a big problem,
because usually you use the same gear on the high speeds and don't change gears!
Guys on the russian forum has done it, and everything works fine...
because usually you use the same gear on the high speeds and don't change gears! No other problems were found while
testing the system...
Regards, Alex
Look at the last picture on the first installation instruction post... You should use M5x10mm screws for tightening the switch instead of M6x10mm screws!!! Sorry for the mistake.
Can somebody give the link from the RussiaTOCforum where all this is quoted ;)
Look here please!
Hi, I have a Auris 1.4 D4D Manual transmition, and i bought the bits and install, the cruise control doesn´t worked. :angry:
I' ve found this document http://www.thecruisecontrolstore.com/toyotawiring.pdf
it says that a wire between ECU and a conector behind steering wheel is missing, the problem is that this document is for corolla and prius, and the ecu pinout is not the same.
Can anybody check this for me, anyones knows were to find the ecu pinout?
thkx!!!
Auris come to russia only with petrol engines, not with diesels. If not working with 4zz-fe (1.4vvt-i), work sure with 1.6 dual vvt.
Maybe and with 2.0 d4d.
Hello guys!
I've installed CruiseControl to my car today. And YES, it WORKS!!
It's just wonderful, loving it allready.
Hello guys!
hey, the HID kit in your signature pic, is that factory or aftermarket?
Hello guys!
Hello Modena!
The kit is aftermarket, it's 6000k from Cobra...
Hello guys!
Hello Modena!
Could you post some more clear photos, like the projection onto the wall, view from the front and back etc.
Also a link to cobra site??
I am interested in getting a kit for mine.
Thanks!
Hello guys!
Hello Modena!
Thanks!
Ok, will try to do that as soon as possible.
I'll make some photos in the dark and
post them on this forum. Will give you the
link to the Cobra site then too...
Please check my Introducing my Auris! -post for further details... I will post
the pics and information regarding my
xenon kit in there!
Best regards, Alex
Hi everybody ,
so i got Auris 1,4 Petrol (4ZZ-FE) and i'm curious why this cruise control do not work on this engine ? If anybody have some idea ? I got the "CRUISE" sign in the left side next to RPM, got two cover caps .. everything. Why this works only in 1,6 Petrol. Does anybody try to put cruise on 4ZZ-FE to see will it works ? I really want to install this thing on my car because is so easy to drive on highway. Thanks in advice!
