Condensation In Headlight
kevensis
Hi all a few weeks ago i changed the dip beam bulbs in both headlights (not the easiest of jobs) now every time i wash the car i get
condensation in the drivers side light could it be the cover on the back i have had a few goes at fitting it back on and it looks like
its on right, could it be the rubber seal running round the edge, never had a problem until i changed the bulb.
cheers kev.
cheers kev.
Hi Kev, I understand what you are saying but Toyota will probably replace it FOC if you take it to the dealership, I had both mine done. I'm pretty sure they also extended the warranty on the headlamps.:thumbsup:
Regards, Pete.
cheers kev.
Regards, Pete.
thanks for the quick response pete, would the warranty still apply to my car its done 104000.
cheers kev.
Regards, Pete.
Now i'm not sure with that mileage mate but I would give them a call anyway.
Best of luck anyway, Pete.
As to the fogging there is two reasons,
1) rubber caps you replaced wrongly
2) cracked glass
every time i change bulbs i have problems fitting the rubber caps, takes me like 2 minutes on each fiddling with it.
Headlight condensation is a known issue on the second generation Avensis. I don't think they did a pro-active recall but if you take it to a Toyota dealer they should check if your car is affected and replace if necessary. As far as I know this is not tied to warranty so your car's mileage should not matter.
If you Google this issue I am sure you will find more details. I know Which? magazine had an article on it at the time (a few years back).
Hope this helps.
