2010 Rear Bumper On Pre Face Lift
Crasstoe
As above? Its the one with the diffuser like this;
I would like to keep the pre face lift rear lights, will this cause an issue?
Thanks in advance,
C
As above? ...I would like to keep the pre face lift rear lights, will this cause an issue?...
If you replace the bumper only, you'll find a gap (half inch aprox.) between the rear lights and the new bumper, therefore you have to change the rear lights too...
Guess I'll go with the Toyota Skirt and twin exhaust then...
  • 3 years later...
I'm guessing the newer model lights still have the same mounting points?
The gap doesn't actually look bad at all I don't think. Hardly noticeable unless you're right up next to it! I think this bumper really makes the car look better as the pre-facelift bumper looks a bit plain.
Yeah it's not that bad. But if you're going to install the new bumper, you should do something to the reflectors. For example install some LED lights in there which will double your rear lights :)
If anything I would make them reverse lights, the standard ones dont give you very much light at all!
Sent from my GT-I9300 using Toyota OC mobile app
