hi everyone im new here so could someone tell me if corolla t sport 2001 front pads and discs are the same as a 2003 corolla t sport.thank you
Yes all the pads and disks are the same for the t sport 01-06
Even for the compressor too
Welcome to the club
welcome to TOC.
If i'm not mistaken then the 2.0 diesel, t-sport, and compressor all share the same front brake disc size/setup. There are variations in the rear disc size all I know on that is my diesel takes the larger of the 2 sizes.
Hope that helps.
hi and thank you for your help ,some list 01 and some list 02-04 ,thanks again
So if were to fit a set of diesel calipers and disks on the rear I could have a bigger brake set up on the back.
Take it that they will be the same size as the front?
rear discs are the same size on t-sport and derv.
the 1.4/1.6's are smaller both on the front and back.
front t-sport/derv: 275
rear t-sport/derv: 280
Didn't know that thanks
no problem! the discs on the rear are bigger purely for the fact they run an inboard drum on it. im awaiting the post, one day, asking.....can i fit the bigger rear discks to the front and hte smaller on hte rear. hahaha. besides the rear pads are tiny and the piston itself is smaaaaaaaaaaaaal.
