Aygo 2007 Baffle Plate Oil Leak
Aygo 2007 baffle plate Oil leak
The baffle plate is located behind the inlet manifold and is a bit involved
The way I did it was
Disconnect Battery
Remove the front bumper
Remove the alternator so you can get the cat out
Remove the all in one exhaust manifold cat assembly
Drain water
Remove the water pipe
Then you get access to the baffle plate
I used the recommended ThreeBond 1207b sealant but I suppose a gasket could be made refit in reverse order
post-104635-0-04783100-1297792163_thumb.
post-104635-0-18387100-1297792178_thumb.
post-104635-0-29538200-1297792193_thumb.
post-104635-0-84640300-1297792206_thumb.
post-104635-0-92116200-1297792224_thumb.
post-104635-0-79015000-1297792242_thumb.
Excellent clear and concise post, love the well composed photographs.
Ever thought about making a service manual.
Hmm, never seen anything like that before,
baffle plates usually in the sump? But I suppose to make the engine more compact the baffle plate is vertical down the side, kind of like what Ive seen on motorbikes.
Do you think this has been a problem from new. Not enough sealant used to hold the plate on, weeps a bit then eventually gets worse. Had the same problem on a sump on another car not Toyota. No gaskets used, plate is probably fitted by robot in factory.
Hi geezbeez yes you are right some of the sealant was missing in places hope its fixed now
Bill
Hi gizmo999 thanks ..... i do have the toyota workshop manual but it not as good as photos hope the post helps others
regards
Bill
nice jod gates!
photos always help. :yahoo::yahoo:
  • 3 years later...
Thanks for this ! just discoverd this on my 08 Aygo. dry dipstick car not burning oil and no oil in water, but i can see how dirty and oily it looks down at the front near the baffle
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
