Engine Occasionally Cutting Out When Stopped.
cottr212
Hi there all members.
I am new to these forums and was wandering if anyone could give me any help to this problem. My vehicle has just completed over 100,000 miles and is a a TOYOTA AVENSIS D4D T2 on a 58 plate.
Symptoms:
1. The rev counter needle can be erratic when I pull up and stop the vehicle - fluctuating between 1000rpm and 800 rpm.
2. The engine has never cut out when the vehicle is in motion.
3. The car will always restart.
Actions already taken:
1. Air filter changed.
2. Fuel filter changed.
3. Egr Valve cleaned.
4. I have put REDEX in the tank.
Any ideas would be welcome.
Many Thanks.
Hi your vehicle needs the latest software and suction control valve .there is a service bulletin relating to this issue .checking the gauze in your tank unit for blockage is also necassary.main dealer job only
Kev,
Thanks for your reply. Do you have any idea how much the cost is likely to be?
Price varies from dealer to dealerbut a word of warning you will need a dealer thats well clued in.ive seen numerous posts from people wit this issue and there dealer doesnt even know a tsb exists on this issue .id love to post the tsb and software numbers but as i wrk for toyota i cannot leak this info
Thanks Kev,
I am already having problems with toyota trying to establish tsb exists and software update. I will keep researching,
Regards
