Scv Avensis Where? (Diesel 2.0 D4D 06/2003)
gallier
hello,
where are the scv's located?
has somebody picture or something else?
avensis (model 2003- 2006)
best regards,
Hp2 system has two on the high pressure fuel pump 1 red 1green .hp3 sytem has one on the high p fuel pump fixed by two 5mm alan keys .the pump on 03to 06 ave 1 cd engine is drivin by t belt and located drivers side front of engine below ps pump
My 54 reg D4D has a single 'silver' coloured valve. You can see it in the enclosed pix, hiding behind the cable loom. I have a spare which i haven't had the courage to change yet, partly as I forgot to get a gasket set at the same time. I had hot starting problems last autumn which went away when I changed the Battery and winter came. Problems 'started' again last week. Pouring cold water on it for a minute and the car starts again so it seems to be a likely reason - there again mr T reckoned my 4 month old Varta Battery was shot when he MOT'd it last week....
Pic of spare part enclosed.
post-58441-0-36885500-1336295129_thumb.j
post-58441-0-13196400-1336295150_thumb.j
  • 4 weeks later...
Where did you get the valve?
Is it new?
Mine is doing the hot start dance too.
Am I right in thinking these are solenoid lifters, that adjust the pump output?
Solenoids are a common fault on boilers, where they get intermittent faults when hot.
hello,
best regards,
hello
both SCV are mounted on the fuel injection pump.
you ll find them easily
regards
Igor
