7A-Fe Crankshaft Pulley Buying From Ebay
Konrad C
Yesterday one of my drive belts got thrown and shredded, plus the crankshaft pulley is wobbling. I heard the racket and stopped to the car the first timeimmediately. Replaced with a spare I carry then drove home a short distance. I did not know the pulley was damaged until I inspected it on the drive at home.
I am aware of the design of the pulley, with rubber being used as a vibration damper - the rubber is the weakness.
I have checked on the net for a replacement.
Eurocarpart sell it for £150.
eBay seller azcarparts sell it £42.30 including post. I don't know the contition of the part - is it new, recon, or secondhand. Also can anyone recommend the seller? They seem organised.
Due to work. I will not get time to go to breakers yards, plus one of the breakers over charges and tries to make you buy a whole part you don't need. They seem to think they know how every car is made.
Is there any other carpart specialist I could try? Any suggestion is welcome.
The fitting is the easy bit, just getting the part for a 14 year old car the hard bit.
I wished the pulley was all solid metal. Does this version exist? Other cars get by.
Thanks in advance.
Konrad
Quick update.
My local spares has ordered me a new pulley for £105.
Should have it by tomorrow latest.
The old one has totally split - you can turn the outer part of the pulley by hand! As I said before, the pulley did 14 years.
Hope you are all enjoying the Olympics. I also enjoyed a good bike ride too, so my weekend was not ruined.
Very unusual for the harmonic damper to break up and part company from the pulley,
I doubt if you will experience the same problem again.
Nice easy job to replace as long as the 19mm crank bolt un-does easy enough.
Good luck
Quick update.
The local shop ordered the wrong pulley! I found out when I removed the old pulleyand opened the sealed box for the replacement.
I checked the web site of the manufactor and found the correct model. Unfortunately the shop tried and could not get the correct pulley. I got a refund.
Phil, my technique to loosen the centre bolt, is to disconnect the coils, place a torque wrench on the bolt and against a strong part of the car (with padding if necessary), then quickly turn the ignition key for a fraction of a second. Then undo the loosened bolt. Easy.
That is what I have done with a few cars with stubborn crankshaft bolts.
I contacted the eBay supplier and he confirmed that he had the correct new pulley, with 4 on the shelf. He is sending it to me for £42.
I did a price check with Toyota and it costs £292.31, Eurocarpart £150, the local £105. Big differences.
I recall reading about the pulley failing on the forum a few years ago. After 14 years it can happen. I also found out that a few of makes of cars have damped pulleys fitted.
Once the pulley arrives, I am up and running.
Had the same problem with my old Fiat Marea, it actualy came apart completely and shot it out from the front of my car, scarey.
Final update.
I received the pulley from azcarparts and it is made by Febi. After a bit of learning how the tensioning system worked, I had the pulley and belts fitted.
The best £42 I have spent.
I have added a few pictures.
post-76861-0-69558700-1344641550_thumb.j
post-76861-0-40968100-1344641586_thumb.j
post-76861-0-55956800-1344641643_thumb.j
post-76861-0-02781500-1344641695_thumb.j
  • 3 years later...
For those who might have a failed pulley the replacement is a Febi 27231 for 7A-FE & 4A-FE leanburn engines.
http://www.ebay.co.uk/itm/FEBI-27231-Belt-Pulley-crankshaft-/400785724132?hash=item5d50b0d2e4:g:1RsAAOSwU9xUNSNO
There are quite a few Mk1s out there, and the pulley will be very old by now.
