Indicator Fuses Location On Avensis 2007 Estate
darrellneth
Hi All
Can anyone tell me the location of the fuse on a Avensis 2007 estate for the indicators, I have found the
fuse panel behind the glove box but does not tell me which one, unfortunatley the car came without the manual, indicators not working after change the wing mirror.
Darrellneth
Welcome to the club Darrell. Have copied your post onto the Avensis forum as you're more likely to get a response from members there
I'm currently having the same problem with indicators I've found my fuses there fine but still my indicators don't work think it maybe my relay that's give up the ghost
  • 5 months later...
Hi garry1999 yes I sorted it mate it was my relay that's behind the clocks It's easy to get to you don't need to remove the steering wheel just the ignition barrel covers and a few screws that Hold the clocks in place the clocks just pull out fixed mine in 20 mins private sesame me if you need other help
