Power Steering Reservoir
BigMo82
Silly question but can someone kindly direct me to where is the power steering reservoir on the T25's?
Mo
On my 2007 Avensis the power steering reservoir is under the plastic cover on the drivers side behind the coolant header tank.
Fitter
Thanks for the reply.
Mo
Clean the crud off the top before you open it, just so nothing drops inside.
  • 7 months later...
Hi there, gotta same problem, even desperately trying to find power steering reservoir ! I've got Avensis 1.8 vvti 2008.
Can pls some one post pictures where mentioned reservoir is located. Could not found it behind coolant header tank, definitely.
Thnx in advance
i belive on the 2008 1.8 vvti which i also have the power steering is electronic and so dosent have a fluid reservoir.the only reservoirs i have are for the brakes and the clutch.
thank you, but what can cause slight buzzing while turning the steering wheel ?
check to see if your wheel arch cover is loose,during last years snow a build up of ice behind my drivers side cover pushes it loose and i got a grating noise when turning on inspection i found it loose and it had a large hole worn into it,repo part of eBay cost about £25.
