Obd Diagnostic Tool For Diesel Engines
T25-AVENSIS-D4D
Hello to all!
Does anyone has tested MINI VCI FOR TOYOTA TECHSTREAM - diagnostic tool ?
I want to buy it but i think that it is not suitable for diesel engines.
I have a toyota avensis D4D T25 2005.
Sorry I haven't BUT I would like to know how many hours you spent on the engine paintwork job, it looks really good and how did you go about doing it! :thumbsup:
Regards ..... Pete.
The engine was rebuild after a lot of work!
yes i have one good investment !tho ya need to know a bit about diagnostics.its a bit hard to use unlike the peugeot planet which is user friendly!
Hello to all!
Yes I've got one end it works on my Avensis D-4D 2006.Problem is there is no manual for using it, I mean I see live data but I don't know what are the limits (min/max) of readings...
You can see demo here:
https://techinfo.toyota.com/techInfoPortal/staticcontent/en/techinfo/html/prelogin/docs/ts/tsUserDemo.htm
Here are my screen shots Idling and about 3000 trns :
I need somebody to interpret screen shots if everything is OK. For example always my Fuel Pressure is lower then Target Rail Pressure. You can see it on second picture (3000trns). On idling now is OK, even higher, but it is accidentally now, usually is lower as well.
post-14699-0-48274600-1370442204_thumb.p
post-14699-0-42492800-1370442221_thumb.p
  • 7 months later...
you have a lot of sensors there. I have just some
I mean no information for admissible limits (min/max) of any value of sensors and parameters which could be seen with Techstream for different engines.
  • 9 years later...
what should the injector readings be at idle and at say 2000 rpm?cheers for any any answers, john.
