Headlights!
Dermot
So i bought a Mark 2 T3-X and was changing dip bulbs yesterday. The bulb holder in the driver headlight is broken, seems to be a common problem.
So do i buy a used one and hope it'll be ok? Or buy a set or spurious headlights and hope they'll be better than a second hand unit?
Don't know whether these may be worth trying - http://www.ebay.co.uk/itm/H7-PLUG-IN-CERAMIC-HEADLIGHT-BULB-HOLDER-2-TOYOTA-AVENSIS-CAMRY-PICNIC-BH107A-/171059486667?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27d3f09fcb - though you would need to check with the seller that they would fit the 2004 Avensis
Cheers, but it's the bulb holder/clip. Not the wiring.
The Avensis headlamps were modified to stop that happening, a second hand one will probably have the same fault. Buy new, ive seen some horrible non genuine ones that just dont fit! Genuine ones are quite pricey
Kingo :thumbsup:
