Hid Installation
Aidsy1
Decided to show pics of me installing the HIDs I received today, dunno if there is a guide yet, but here is one. I got the 6k bulbs from eBay.
First thing was remove the shroud that is around the front of the engine bay:
Then to access the front passenger side light easier I removed the air intake duct:
Then remove the original bulb and unplug the wire that goes to it.
Now plug in the new bulb into the existing hole:
The next step is to find somewhere for the ballast to go, i decided for it to go on one of the bolts for the Battery support.
Next you'll need to plug all the wires in (its quite simple, they are designed to only go in one way) the only problem with mine was that there was no plug to fit in the original light plug (i cant describe too well) so i had to put the pins that were provided into the appropriate socket:
End result is:
