Hello Forum Members! This has probably been reported a number of times so if someone can point me to some good links / previous responses that would be great I have a 2008 Auris and there is about 10mm of water in the passenger side rear light cluster From the postings I've seen the fault should be due to a perished seal. I'm guessing the advice is remove the lens - drain any water and then replace with a Toyota Light Seal Kit? As always any guidance would be appreciated Regards Stu
