I spent a while searching how to retro fit cruise control to my Corolla (see title) and eventually decided it was doable and jumped the gun and went off and bought this secondhand on eBay....
I took the airbag off yesterday (just the spring to be pressed up, not two torx screws that I have seen everywhere else) and found this....
As you can see the cc stalk does not fit on the wheel.
Can anyone help and tell me if cc can be added to this model using this wheel?
If the cable fits and it activates and works then it can be fitted however mounting will take some careful drilling
Sent from my HTC One SV using Toyota OC mobile app
If the cable fits
It doesn't.
So back to my original question...
This stalk is not compatible with your ECM module, it's not programmed for CC, even it hasn't got a pin for CC. The only solution for retrofitting a CC is an aftermarket kit with actuator.
Ok, thank you very much for that advice. Can you recommend an aftermarket kit?
Rostra universal kit 1223 from US is working for sure...
I would much prefer a fly by wire system. I have asked Rostra for a recommendation.
Thanks for your help tavy :thumbsup:
You're welcome, Gary !
  • 5 years later...
It is available to install cruise control in toyota corolla 1.4 d4d 2005 model??
