Electronic Owners Manual
FROSTYBALLS
Electronic owners manuals are available to download in pdf format for some Toyota models by accessing the following link: https://www.toyota.co.uk/tme#/my-toyota/eManual
Manuals are currently available for models made from 2011 up to and including the current model.
  • 3 months later...
When I click on the manual it says your connection is not private, click back to safety????? Whats that all about?
Some browsers pick up a certificate error.
However, the site is an official Toyota Europe website and the link was obtained via the Toyota UK Blog. I have accessed manuals and downloaded information from there countless times on different computers and tablets without any issues and without any security problems.
The link in the first post is the official Toyota Europe customer portal, and the Owners Manuals are available from there as and when they get updated.
hi. I have a question that is not related to the topic. only reason I am asking here is because I am new here and for some reason can't start a new topic. what the best offset for 17" rims on 2008 auris?
  • 7 months later...
Hi all new in here but does anyone know where I can get a workshop manual for my 2008 toyota auris sr180? Digital version if poss cheers
I haven't heard of one but depending on what info you need maybe it would be similar to the Avensis of the same age, for which there is a pdf workshop manual around on eBay etc. It's not got everything in it but I'm pretty sure the engine stuff would be similar.
I'm after the sections regarding changing front and rear disk,etc thanks
Would the 2009-2011 Corolla manual be ok?
There's a section on brakes, they'll probably be similar to the Avensis ones.
Would the Corolla 2007-2011 one be any good? Cheers
I can't answer your specific question, but broadly speaking the procedure for changing brakes is similar from one car to the next. You need to get the pads out, the caliper out of the way, the old disc off, and refit in reverse order, cleaning and lubricating parts as relevant. Rears can be a bit more complicated depending on whether it has handbrake shoes, or the caliper needs wound back, or the hub is integral etc.
