Avensis Mk2 T25 & Facelift Rear Light Cluster
avensisd4d786
I like the look better of the facelift rear light clusters (the facelift has silver rings)- does anyone know if these are a straight swap.
I have a 2004 and would like the lights of a 2006+ model (facelift)
post-125194-0-00104600-1410192540_thumb.
post-125194-0-98935100-1410192559_thumb.
post-125194-0-41523500-1410192568_thumb.
post-125194-0-44087900-1410192582_thumb.
Hi Im.
The shape is the same. The problem is the wiring connector to the bulbs. Obviously I don't have your model, but if a member has a facelift T25, they could take a photo of the connector and wiring to the bulb holder.Then you can compare with yours.
Konrad
Hi Konrad,
I'm going to learn the hard way, I got them at a cheap price if they do not fit. I'll put them back up for sale.
You could probably change yours too.
post-125194-0-04243300-1410381473_thumb.
post-125194-0-39086900-1410381501_thumb.
Hi Konrad, They fit like a glove, The bulb holders where the electrical connectors go had the same part number- so they are 'straight swap' no modifications.
To be honest I found it easier/less awkward to change the whole rear cluster than a rear bulb which has been a pain in the a** in the past.
That's great news Im.
I know that the phase two mk1 lights will fit, but I like the original. I was going to tell you to make sure it is the same type (hatch/saloon/estate) as your car, but I knew you made sure.
Too bad you can't change the fronts as easily. I think the bonnet bumper profile is slightly different. I could be wrong.
Konrad
Yes I did make sure, Yes the estates are totally different not sure if the saloon are the same as they look similar,
Yes the front bumper is different, I have already looked into that one.
Would it be possiable if you can load up a few shots of the new rear light clusters please. Im interested in doing the conversion too! thanks.
There you go Please excuse the dirty car. I bet they would look better on a black car, what colour is yours?
Ill get a better picture this week if you want another shot.
I'm actually in two minds about them.
post-125194-0-50707500-1414522443_thumb.
post-125194-0-90810400-1414522447_thumb.
Very good Im. :thumbsup:
I also notice another Avensis in the photo. :)
Konrad
  • 9 months later...
Hmm think an upgrade has been added to the list
