Recall For Auris, Yaris, Urban Cruiser, Iq And Corolla
FROSTYBALLS
The latest recall is reference R/2014/160 and the recall began on 7th January 2015. The recall affects the Auris, Yaris, Urban Cruiser, IQ and Corolla built between 13/11/2008 and 13/09/2013.
Description: Oil may accumulate in the turbo charger and, in certain circumstances, flow into the combustion chamber. This may cause engine damage. In extreme cases oil can be ejected from the engine and if it comes in contact with an ignition source may result in a fire.
Remedial action: Depending on vehicle diagnosis, modify intercooler layout to improve air flow; upgrade ECU software; upgrade turbo charger and/or vacuum pump.
Use Toyota's recall checker to see whether your car is affected - http://www.toyota.co.../recall-checker
I I remember I will take pictures of before and after but hard to say if there will be much to see
you'll see the pipe work mod for sure, ecu update hard to see , turbo ,vac pump will look new if they are needed.
Rob
Booked in now for early next month.
Your right pictures of clean pipes arnt worth taking.
My Auris is booked in for the recall to see what parts are required. I thought Toyota would already know that? Has anyone had the 'mod' done on a 1.4 D-4D Auris yet? Any problems occurred after work has been done?
it will be a check for what batch of parts were used. ( turbo and vac pump) a rework of the airflow into the engine and ecu firmware check/update.
the checks are simple and quick. subject to parts req'd the time will then be known for the whole job.
Rob.
As stated in the first post, remedial action will depend on the vehicle's diagnosis.
look on the bright side you will get the car washed twice and a loan car when the work is done
rob
our 1.4 D4D auris has been ib for the recall check and needs the new turbo and vacucum pump plus the pipework . going back in on the 17th for the work
Took my Auris D-4D to the dealer today for the recall and it only needed an ECU update which they did while I waited an hour so I'm pleased about that. Mine is a December 2013 registered car so I guess any Auris younger than this will also just need the ECU update.
We were told the work would take 4 hours but an hour to cool before they could start so dropping it off the evening before.
All done.
New inter cooler and pipes fitted. Nothing worth photographing.
