Auto Gearbox
rob47
HI MEMBERS,could anyone tell me what miles would you change the oil in auto gearbox on toyota avensis 2.2 t27 2009, many thanks rob.
I think in general toyota do not state that you change the ATF,at least on the auto RAV4 they don't if there are no probs with it
Del
The transmission fluid in your Avensis is designed to last for the vehicle life, should you wish to replace the fluid you will need ATF WS and someone with the correct diagnostic computer to ensure the transmission refills correctly
  • 4 weeks later...
