IMG_20200217_122716.thumb.jpg.895764988c075fe91b08f0a51207c852.jpghi
Throttle position semsor cable tends to break in Previa.
read code: sort E1 TE1, turn switch on not start.  count flashes of the Engine worning light.
first group tens
second group ones.
4 flashes then 1 flaah indicates code 41, bad TPS.
