When i was looking for a Guide for adjusting the handbrake there wasnt one,so i just thought id knock a quick one up and hope that it may help someone else.
I fitted new brake discs and the handbrake was adjusted fully at the bottom nut,so make sure this is done first really.
The first step is to remove the chrome frame around the gear stick gaiter..see pic
Just a slight pull from the rear lifting it up is suffice.
tutorials-131671-0-90201800-1373470437_t
Next step after the chrome frame is removed is to lift the actual gaiter upwards as far as it will go to aid access.
tutorials-131671-0-19579500-1373470481_t
We now need to remove the trim that will allow access to the handbrake adjustment nuts.
The trim may seem quite stubborn to remove but just grasp the rear of the trim at the back of the gear stick and lift at the same time as gently pulling backwards and ease it away from the gear stick,be a bit careful with this as the wires for the ashtray illumination are attached,i didn;t remove the wire connection i just laid it to one side on the passenger floor out of the way.
This is the view once the trim has been removed.
Next step is to remove the 2 screws which are highlighted with red arrows this to allow the centre console to be removed.
After the 2 screws are removed you need to ease away the console which surrounds the handbrake lever its self,which again be gentle with it but use enough force to disengage the console away from the 2 lugs at the back,it does seem tight but it will snap away just dont go mad with it.
Ease away the the trim indicated by the red arrows.
Heres a view with the trim removed.
The red arrow in this pic indicates the position of the handbrake adjustment screws.
You will need a long 10mm socket like this to undo the lock nut first of all.
You will also need a 10mm open ended spanner to hold the bottom nut whilst you undo the lock nut completely. Dont loose the lock nut like i nearly did.After you have undone the lock nut you can then adjust nut turning it clock wise to take up- the slack,keep trying your hand brake until you have 3 to 4 clicks ,i did mine to 3 clicks but bear in mind you dont want to over tighten the nut as the handbrake shoes are at risk of binding and you dont want tha
After you are happy with the adjustment,re screw the lock nut back on
Next step although not essential is to lubricate the mechanism so its nice and easy to operate, i also sprayed the button as well.
Just reverse the operation to refit everything back
Now my handbrake is perfect.
