Posted by Giddlepin
HINTS AND TIPS ON THIS PAGE ARE NOT NECESSARILY USING THE RECOMMENDED METHODS AND ARE UNDERTAKEN AT YOUR OWN RISK
If you have any helpful information that will assist other members send me a PM with the details and it will be posted here.
Les
KEY PROGRAMMING
AUTO DATA PM GIDDLEPIN for any information needed that is in the highlighted fields.
WORKSHOP INFORMATION From curriedb :thumbsup:
SOFT TOP CARE
REPLACING FRONT DISCS & PADS
REPLACING REAR DISCS & PADS
MAF SENSOR CLEANING
BLOCKED DRAINS
SOFT TOP EARS
SOFT TOP REPAIR
SIDE WINDOW WATER LEAK
OXYGEN SENSOR REPLACEMENT
HANDBRAKE ADJUSTMENT
REPLACING DOOR CARD MATERIAL
VERY USEFUL LINK TO VARIOUS HINTS & TIPS ;)
FITTING A CHE HEADER
PDF PARTS GUIDE jameswhit
