Here's the maintenance intervals
http://techdoc.toyota-europe.com/Maintenan.../aygo/Final.pdf
Here's the service data sheets.
Thanks to a kindly fellow at Toyota for the info. You know who you are :)
Naturally, if you don't know what your doing don't risk your safety. If you do, it's your own fault
