Programming New Keys
Moxy
Hey guys, came accross this the other day, though it might be of some use :thumbsup:
Programming a key for central locking:
Driver's door open and key removed from ignition switch
Insert key into ignition switch, then remove it.
Within 40 seconds: Close and open drivers door twice.
Close driver's door
Insert key to ignition switch
Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes.
Remove key.
System should now lock and unlock vehicle, once or twice depending which mode has been selected.
Carry out the following button procedure within 20 seconds:
Yaris build in Japan and Yaris Verso: Simultaneously press and hold key lock and unlock buttons for 1-1.5 seconds.
Yaris build in France: Press key lock button for a minimum of 1 second and release
Within 3 seconds:
Press key lock button for a minimum of 1 second and release.
NOTE: IF SYSTEM LOCKS AND UNLOCKS VEHICLE TWICE, PROGRAMMING PROCEDURE HAS NOT BEEN COMPLETED. REPEAT BUTTON PROCEDURE.
If required repeat button procedure to program remaining keys.
NOTE: TO EXIT PROGRAMMING MODE: OPEN DRIVER'S DOOR
Adding a key for the Immobilizer:
Obtain 1 programmed black key (see above)
Within 15 seconds: Press and release accelerator pedal 5 times.
Within 20 seconds:
Press and release brake pedal 6 times.
Remove black key.
Within 10 seconds: Insert black key to be programmed into ignition switch.
Within 10 seconds: Press and release accelerator pedal once.
Immobilizer warning lamp will flash.
After 1 minute immobilizer warning lamp will extinguish.
If programming another key:
NOTE: A MAXIMUM OF 7 BLACK KEYS CAN BE PROGRAMMED. TO EXIT PROGRAMMING MODE: REMOVE IGNITION KEY AND PRESS BRAKE PEDAL AT
LEAST ONCE WITHIN 10 SECONDS, OR WAIT 10 SECONDS.
I feel a wind up coming on!
I can see all the Yaris owners getting either locked out of their cars or being led on a merry goose chase!
You forgot to mention you have to stand on one leg and wear a pom pom hat when you do it!
Is that for real? :D
:lol:
Yeah its for real. I got the info from AutoData CD 2004. This is what a garage would do to configure a new key!
posted the immobilers one somewhere else, dont know where the moderators have moved it to
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
