Constant 12v +
eternity575
hey..
installed my new ICE..
minus is fine..
plus is the old one..
but the remote.. needs constant 12v (even when the switch is off)..
i tried the lighter.. no luck..
besides a direct connection to the Battery.. any other suggestions?
thnx! :group-cuddles:
I take it you didn't get the adaptor?
I think it's the gray wire, I've been looking through the how to's and the gray wire is connected to the remote wire.
check the link, I know it's about connecting an amp, but it may work
http://toyotaownersclub.com/forums/index.php?showtopic=17514
If you are using the standard HU like i did in my last car with an amp!
I just spliced the remote lead into the 12v supply to the cigarette lighter, i dont see why it wouldnt work for you!
Did you splice it in or cut the wire to the lighter completly?
CB :thumbsup:
