Hi all,
I usually spend my time in the Avensis section but now my wife wants to change her Yaris and due to expanding family the Rav 4 looks like a good option. Will be looking at 2002/2003 5 door models and would appreciate any advice on what to look out for.
I haven't actually driven one yet but engine choices here in Ireland are poor. I suspect that the 1.8 VVT-i for that size body would be very sluggish and can't see much of an improvement in the 2.0.
How does the 2.0 D4D drive. We put a lot of milage up at weekends so if I purchase a D4D it will be doing most of them and I will only use the Avensis for work.
What is the ride like, reading through some of the posts here it sounds good.
Hi all,
Don't like to see posts unanswered :rolleyes: .....there seems to be a few problems with the D4D at the moment ,see this thread as one example......
http://toyotaownersclub.com/forums/index.php?showtopic=47973
and another...
http://toyotaownersclub.com/forums/index.php?showtopic=42688
Own a Rav4 D4D since Jan 2002.
A bit noisy, but it is a diesel so expect a bit of clatter.
It took toyota dealer over 3 years to fix noise from accessory belt.
(check that the mod is fitted to the power steering pump mounting-4 washers-).
Warranty expired in Jan 2006, but bought extention for two years more.
There is still an unresolved problem after all this time--- Gear lever rattle in 5th gear.
Dealer said that mod was done in the gear box, gear stick and gate assembly replaced but the problem is still there---CONSIDERING my next move!!!!!!!!
In other words buy a suzuki.[/i]
Thanks for your responses.
D4D on Rav is now not looking a good option.
Cheers
Hi all,
aven_man, don't worry about the petrol version being low on power, I have an XT4 2L and it has 147bhp (manufacturers spec). It goes like stink if I put my foot down and the RAV4 has been called the GTI of 4x4's by some parts of the press :)
As for the ride, it's excellent for a car of it's hight/size. Once I got used to it I started to drive it like it was just another family saloon car with added benifit if excellent traction due to the 4 wheel drive
Hi there,
I've got the 5 door 2 litre petrol VX as my wife's car - it's great - not the most refined of engines (I drive a beemer so maybe I have high expectations!) but a great all round family car, and ultra reliable so far in a year of ownership.
I'd thoroughly recommend it to anyone.
Cheers,
Ali
Thanks johnbr and ahmurray
I am thinking of importing one from the UK. On a 2003 RAV4 2L VVT-i could save up to 8k euros compared to Irish prices. Also UK models are have a higger accessory list compared to Irish models.
I will let you know how I get on.
Thanks again.
