Programing Key.
SHREDDER1uk
Hi guys just a quick question i found a spare remote key in my glove box for the t sport but it don't work. Is there a way to programme it myself or is it a dealer visit..
Dealer visit only I think
Hi Shredder
Does the key start the engine? If it does then the key is recognised by the immobilizer. If it's the remote central locking that doesn't work, try sitting in the car, having opened it with the other remote. Press lock and unlock repeatedly. This should resynchronise the remote to the car. It can take ten tries before you get a response. After that there is a special sequence of door openings etc. Try the key first, if that fails post back with your model number from the VIN plate and I'll look up the sequence for you. Model number will be something like ZZE121. Regards Ray
I'm sure there's a guide how to do it on here -you could try using the search and see what that brings up?
Cheers guys ill give it a try at the weekend and see what happens if it starts the car ill try the unlock lock thing if not ill pm you my details.
Many thanks.
May be stating the obvious but......does the LED on the key light up when you push lock/unlock? It could just be the battery! :o
Yes it comes on :P
Have a look here - Linky
And PM those guys :thumbsup: !
I have also read that it tells you how to re-sync (not program) in the manual ????
*I'll keep looking and see what I can find
Have fun following that link! :thumbsup:
